3 members (panic, 2-Ton, 1 invisible),
133
Mod | | | Forums66 Topics128,260 Posts1,058,343 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 159 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 159 | I have a 37 GMC and was wondering if anybody has used any of that spray foam that they use to insulate houses or use in shiping packages. I seen some and was just wondering if it would be any good or not. Thanks
1938 Gmc 1/2 ton
| | | | | Joined: Aug 2005 Posts: 6,379 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,379 | Where are you wanting to use that as insulation? If it's anywhere water can get in you are asking for trouble. If you're wanting sound deadening I think you're going the wrong direction.
| | | | | Joined: Aug 2005 Posts: 278 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 278 | I used spray on urathane foam on a corvair van. It worked well substantually stiffening up and insulating body panels. Where it did not work well was inside closed door panels/corners. It can trap existing pockets of dirt and rust that can excelerate future rusting. | | | | | Joined: Aug 2005 Posts: 6,379 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,379 | It can trap existing pockets of dirt and rust that can excelerate future rusting. Bingo!
