8 members (Perro, Hush, Lightholder's Dad, John L., Otto Skorzeny, lumbersawyer, FAST55, Hanks custodian), 182 guests, and 6 robots.
Topics128,075
Posts1,056,007
Members48,433
#48661 08/04/2005 2:24 AM
I have come across a torque tube for a 53 passenger car (3.73 gears) that I'm considering putting under my '39 1/2 ton truck. I'm aware that I'll be going to 5 lug. The width and length will work. My question is; will I have any problems with the trans splines mating to the torque tube? Any thing in particular that I need to know?
#48662 08/04/2005 5:11 AM
gaffbro -
I've done that on my 37 1/2 ton pick up. I replaced my 4:11 stock rearend with a 54 passenger car POWERGLIDE rear end. It is a 3:54 gear ratio. The 3:73 passenger car STANDARD rear end will help you a little, but not nearly as much as the POWERGLIDE will. There is not that much difference between 4:11 and 3:73. When I did it 20 years ago, I was told NOT to use a STANDARD 3:73 rear end. You'll pick up about ten miles per hour with the 3:54 rear end. It will, obviously, be less with the 3:73 rear end. I don't think five miles per hour is worth the effort.
Length wise, I had to shorten mine. Your wheel base may be about 1 1/2 inches longer than mine, but I think you will have to shorten the torque tube and propeller shaft.
You will go to five lugs on the rear. The U-joint on a 39 truck is 10 splines. I think it went to 17 splines in either 1940 or 1941. The 53 Chevrolet car is 17 splines. To match them up you will have to buy a 53 car u-joint, unless you get it with the rear end and mate the two u-joints together. They will mate together, it's not really a problem, but that is something you will have to do.
To get five lugs on the front of your truck, you will have to have a 41-54 truck axle, which will bolt under your truck, and use the 50-54 car backing plates and drums. They will not fit on the 39 spindle, but will on the 41-54 spindle. The axle is a bolt in changout. Then you'll have five lugs all the way around.
I wrote an article on this and I can email it to you if you drop me your email address. Mine is:
[email protected]
#48663 08/05/2005 3:03 AM
6cylortehas: Really appreciate the information. This is exactly what I want to do. A low budget upgrade that will get a little more hwy speed.
#48664 08/23/2005 10:00 PM
is there a way, to determine what rearend ratio you have without opening the punkin?
"So many trucks, so little time!"
Vehicle list:
down to 2 now.
1 - 1967 Chevy 3/4 ton LWB 4x4
2 - do I dare say it??? a 61 Ford Unibody
#48665 08/23/2005 11:25 PM
Jim Carter used to have a tech tech describing this swap (expecially the Powerglide swap). As I recall, he stated that you could retain the 6-lug rear wheels by obtaining 6-lug axles from a late-40s/early-50s Chevy Passenger car's torque-tube rearend. Those 6-lug (automobile) axles supposedly fit the Powerglide torquetube.
