4 members (ndkid275, 2-Ton, Shaffer's1950, Otto Skorzeny), 159 guests, and 1 robot.
Topics128,048
Posts1,055,539
Members48,424
#486421 12/26/2008 2:00 AM
does anyone know if a 1 ton(3800) uses the same u joint as the 3/4 ton( 3600) ALL I HAVE TO GET TO FINALLY LET THIS TRUCK MOVE UNDER ITS OWN POWER IS THIS U JOINT, will go to parts store tommorrow and do not want to get the wrong part,thanks trying
trying #486437 12/26/2008 2:27 AM
Probably ... I just replaced all 3 u-joints on my 1950 1.5 ton and took the driveshaft into the NAPA, where they measured the cap size and overall joint size. It was a standard size.
Should be no big deal ... good luck!!
-Dan
54Dan #486443 12/26/2008 2:42 AM
Take your old one, or the measurements, to the auto parts store. They will have them in stock.
My 52 2800 has Spicer 1350 series U-joints, I think a 3/4 ton is the same.
If given a choice between Spicer and another brand I always choose Spicer, they seem to be stronger and last longer, and don't cost much more.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
