Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
6 members (walter74, Bill Hanlon, 68ironhead, JW51, Greg_H, Peggy M), 63 guests, and 2 robots.
Topics128,009
Posts1,055,296
Members48,419
#486015 12/24/2008 7:37 PM
j54
Offline
Santa has arrived and I just got some headers for my my 54 3100 with 61 235. I'm running the factory intake and I was wondering how I need need to plumb a heat tube from the bung on the header to the intake. Do I need to just fabricate a plate to block of the bottom of the intake and run a pipe out? Anyone have pics or ideas of how they heat their intakes? thanks
j54 #486093 12/25/2008 12:34 AM
Several of the vendors make a heat kit that you can just bolt on. You can also get one from Tom Langdon. You could make your own if you prefer. The catalogs will show a picture so you can get an idea what's involved.
waldo53 #486106 12/25/2008 1:13 AM
Jim Carter sells the simplest (HPM544) intake manifold heater kit. It will work fine with a standard intake manifold.
Some people use water but it is more complicated and the water does not truly circulate unless the intake manifold (and plate) are set up for circulation throughout the intake manifold.
Clifford intakes and Offenhauser intakes will circulate water with the correct heat plate kit (Tom Langdon's kit (that I bought this past summer) will not circulate properly with these two types of water-heated intakes).
