Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
0 members (), 44 guests, and 4 robots.
Topics128,009
Posts1,055,293
Members48,419
#486027 12/24/2008 8:25 PM
I have a 37 GMC and was wondering if anybody has used any of that spray foam that they use to insulate houses or use in shiping packages. I seen some and was just wondering if it would be any good or not. Thanks
1938 Gmc 1/2 ton
TheShoer #486076 12/24/2008 10:30 PM
Ex Hall Monitor
Ex Hall Monitor
Where are you wanting to use that as insulation? If it's anywhere water can get in you are asking for trouble. If you're wanting sound deadening I think you're going the wrong direction.
Tiny #486165 12/25/2008 4:40 AM
I used Secondskin vibration dampner/temp insulation
http://www.secondskinaudio.com/
and herculiner bed liner for the under cab.
http://www.herculiner.com/
~Jim
I used spray on urathane foam on a corvair van. It worked well substantually stiffening up and insulating body panels. Where it did not work well was inside closed door panels/corners. It can trap existing pockets of dirt and rust that can excelerate future rusting.
Donf #486914 12/27/2008 6:13 PM
Ex Hall Monitor
Ex Hall Monitor
Bingo!
Moderated by  ndkid275, Phak1
