3 members (panic, 2-Ton, 1 invisible), 133 guests, and 3 robots.
Topics128,260
Posts1,058,343
Members48,485
#48597 08/02/2005 3:59 PM
I'm looking at an engine that was advertised as a 1966 235, but I believe '62 was the last year for 235s. The owner furnished me these numbers:
3836848 GM30. Bottom of motor: CON4D29R GM16.
I've searched the Archives and used the various lists of casting numbers, etc, and come up with:
235 built April 2, 1959 with 848 cylinder heads used between 58 and 62.
Is that correct? What does the "R" mean?
Thanks for any help
#48598 08/02/2005 5:02 PM
X
X Offline
Seems correct so far. The 3836848 is the head casting number. I'm not sure what the R is after the block casting date. If you can find the engine serial number (on the pad to the rear of the distributor), the suffix will help identify the engine and what it was originally used in.
Curt
1953 Chevy 6400, 1957 Chevy 2dr Sedan
--"Mediocrity is easy, the good things take time"
