1 members (Gray_Ghost),
65
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,073 Posts1,055,908 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#48565 08/02/2005 2:59 AM | Joined: Jul 2005 Posts: 34 Apprentice | | Apprentice Joined: Jul 2005 Posts: 34 | Hey all. Thanks for the suggestions on getting a stuck brake drum removed. Heat did the trick.
Now I have the brakes back together with new rear wheel cylinders, one new p-brake cable, speed bleeders at all 4 wheels, and the system flushed and filled with DOT5.
I'm having 2 issues: I still have (maybe) some air in the lines, since after pumping the pedal will go down about an inch or two less than the first push. I would just think I needed to bleed more (Though I've done it repeatedly very carefully) were it not for issue #2. The brakes seem to only be off or on all the way. With the truck moving at walking speed I push the brake pedal slowly and it does nothing until it reaches a point where the brakes engage VERY hard, very suddenly. Any thoughts about what that might be? Are my two issues related? The truck is a '42 Chevy 3/4-ton Special, if that makes a difference. Thanks for the help -Jon
Jon 1942 Chevy 3/4-ton Special
I don't need instructions. I have a hammer.
#48567 08/02/2005 7:12 AM | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | Yep...brake shoe adjustment is a huge deal on the Huck brakes.
...did you replace/reline your shoes? Even tho they might look great with a lot of pad on them, they might have absorbed grease/oil. Once saturated, they will grab and never work right. Mine were "new" but after 20+ years of being storage, they were junk. That slime on them from the bearings killed em.
If you don't have a shop manual, pick one up. It outlines the procedure for adjusting..After bleeding a bunch of times, I finally cracked the book. 15 minutes of shoe adjustment fixed me right up. No issues for a year. | | |
#48568 08/02/2005 10:06 AM | Joined: Jun 2005 Posts: 221 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 221 | To bleed the brakes just open all bleeders and leave them for about 10 to 15 minutes it will bleed its self just be sure to keep the master cylinder topped up. | | |
#48569 08/02/2005 1:45 PM | Joined: Feb 2000 Posts: 987 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 987 | WHAT?????? V6 JIMMY were did you hear that???? This might work if all your wc were the highest points in the braking system. But I am sorry this is not good advice!
The brake must be bleed by Forcing the Air our with some fluid.
I read a tip about adjusting drum brakes. All you need is a smooth section of concrete and some news paper. Basically what you do is get the truck moving and stop on the news paper. The wheel that stops firts and slids the news paper is adjusted "closer" then the wheel that didn't stop and slid the news paper. Now you will need to decide which wheel you adjust but it will give you a place to start. If this dosen't make sense send me an email and I will try to explain it better.
Good luck.
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | |
#48570 08/02/2005 1:59 PM | Joined: Feb 2005 Posts: 399 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2005 Posts: 399 | I just use one of those cheapo self bleeders (a plastic bottle and some tubing)...Start with the wheel farthest from the mc..Just make sure to keep the mc full..Works just fine, and you can do it by yourself, Steve | | |
#48571 08/02/2005 3:49 PM | Joined: Jul 2005 Posts: 34 Apprentice | | Apprentice Joined: Jul 2005 Posts: 34 | Would the problem I described indicate that the adjustment is too loose, or too tight?
#48572 08/02/2005 8:53 PM | Joined: May 2005 Posts: 70 Shop Shark | | Shop Shark Joined: May 2005 Posts: 70 | First check if there is oil, grease, brake fluid etc. on the shoes and/or drums like an earlier reply suggested.
If the shoes and drums are OK, check the size and position of the brake shoes at each wheel because sometimes there are longer and shorter shoes and if I remember correctly the shorter shoes go toward the front of the truck.
These must be in the correct position relative to wheel rotation as they are 'servo' type brakes that help to apply the brakes as the drum rotates which helps to reduces pedal pressure.
If the shoes are not in the correct position, the brakes will 'self apply' when you 'touch' the pedal and act like you describe.
illegitimi non carborundum
#48573 08/02/2005 11:11 PM | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | Your brakes are too loose....I also wonder if your shoes might be bad/greasy. | | |
#48574 08/02/2005 11:13 PM | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | by the way...I think adjustment is turn the W/C until the brake drags just a little, then back off 4 clicks. | | |
