7 members (Tinker5, chevy51truck, Gdads51, Hotrod Lincoln, Woodcmiami, 3800GUY, Bill Hanlon),
148
Mod | | | Forums66 Topics128,036 Posts1,055,458 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#48523 08/01/2005 8:38 PM | Joined: Sep 2003 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 72 | Hi, I've got my small block 266 sitting on my engine mounts and ready to get them welded? I am going to put in an electric fan on the stock rad, so I want to know the clearances from the faceplate of the water pump to the rad, and the back of the block to the firewall? Thanks.
kskt4 | | |
#48524 08/01/2005 10:41 PM | Joined: Apr 2005 Posts: 196 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 196 | Yer installing this on a washing machine, right? Well, I don't have those dimensions. Oh, on a truck? I'm still new so unless 'kskt4' signifies your truck, you're gonna have to give more specfics as to what truck you are talking about. Rance
66 C10 FS/LB 292/4-spd manual (I also enjoy Hang Gliding) I'm too sexy for my hair, that's why it isn't there
#48525 08/01/2005 11:03 PM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | and we'll need to know what a "small block 266" is as well - we know the dimensions of a 283, 327, 350, but a 266 is a whole new concept - also has it been clipped? is the rad mount original? what driveline you using?
OTOH you could try having the cab, rad and driveline set in place, and it should be pretty simple to see if it all fits!
Bill | | |
#48526 08/01/2005 11:57 PM | Joined: May 2005 Posts: 30 Apprentice | | Apprentice Joined: May 2005 Posts: 30 | Make sure there is enough clearance so that would the motor torque flexes, nothing hits. I would think at least 2 to 4 inches. You'll need to have the cab, front end, and radiator support on. What about the steering? What exhaust manifolds are you using? The steering parts are usually the most expensive part of a V8 swap on an AD if you buy new parts. | | |
#48527 08/02/2005 12:10 AM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | Maybe it's a 265, 55-57 or 58 in trucks. Also were 302, 305, 307 and 400 inch SBCs. Also there was a 262 for a short time, maybe in the seventies.
Baldy | | |
#48528 08/02/2005 3:03 PM | Joined: Sep 2003 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 72 | OOPS, My truck is a 49 GMC 1/2 ton. And it's a 262 small block. The tranny, is from a 77 GMC 1/2 ton as well is the rear end.
kskt4 | | |
#48529 08/02/2005 5:19 PM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | Sometimes distributor clearance is more of a problem than the back of the block, as is steering clearance to the exhaust manifolds, so you may need more than just the block in place to check for clearances. Sometimes the engine can be moved toward the passenger side for exhaust clearance. This will have no effect on the driveline if the engine remains parallel to the centerline.
Baldy | | |
#48530 08/03/2005 4:50 AM | Joined: Sep 2003 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 72 | Thanks, Yes I will have to see if the steering column from my 77 GMC will fit. If not then an Ididit will do. Then get some Borgenson parts, and mount the steering box from my 77 to the frame. One thing at a time though. Pocket book says how far I can go at a time.
kskt4 | | |
