3 members (49 panel, UtahYork, Nick in Manitou), 65 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#48523 08/01/2005 8:38 PM
Hi,
I've got my small block 266 sitting on my engine mounts and ready to get them welded? I am going to put in an electric fan on the stock rad, so I want to know the clearances from the faceplate of the water pump to the rad, and the back of the block to the firewall? Thanks.
kskt4
#48524 08/01/2005 10:41 PM
Yer installing this on a washing machine, right? Well, I don't have those dimensions.
Oh, on a truck? I'm still new so unless 'kskt4' signifies your truck, you're gonna have to give more specfics as to what truck you are talking about. smile
Rance
66 C10 FS/LB 292/4-spd manual (I also enjoy Hang Gliding)
I'm too sexy for my hair, that's why it isn't there
#48525 08/01/2005 11:03 PM
and we'll need to know what a "small block 266" is as well - we know the dimensions of a 283, 327, 350, but a 266 is a whole new concept - also has it been clipped? is the rad mount original? what driveline you using?
OTOH you could try having the cab, rad and driveline set in place, and it should be pretty simple to see if it all fits!
#48526 08/01/2005 11:57 PM
Apprentice
Apprentice
Make sure there is enough clearance so that would the motor torque flexes, nothing hits. I would think at least 2 to 4 inches. You'll need to have the cab, front end, and radiator support on. What about the steering? What exhaust manifolds are you using? The steering parts are usually the most expensive part of a V8 swap on an AD if you buy new parts.
#48527 08/02/2005 12:10 AM
Maybe it's a 265, 55-57 or 58 in trucks. Also were 302, 305, 307 and 400 inch SBCs. Also there was a 262 for a short time, maybe in the seventies.
Baldy
#48528 08/02/2005 3:03 PM
OOPS,
My truck is a 49 GMC 1/2 ton. And it's a 262 small block. The tranny, is from a 77 GMC 1/2 ton as well is the rear end.
kskt4
#48529 08/02/2005 5:19 PM
Sometimes distributor clearance is more of a problem than the back of the block, as is steering clearance to the exhaust manifolds, so you may need more than just the block in place to check for clearances. Sometimes the engine can be moved toward the passenger side for exhaust clearance. This will have no effect on the driveline if the engine remains parallel to the centerline.
Baldy
#48530 08/03/2005 4:50 AM
Yes I will have to see if the steering column from my 77 GMC will fit. If not then an Ididit will do. Then get some Borgenson parts, and mount the steering box from my 77 to the frame. One thing at a time though. Pocket book says how far I can go at a time.
kskt4
