1 members (FAST55),
133
Mod | | | Forums66 Topics128,080 Posts1,055,956 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 1,154 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,154 | HI in order to make things easier for my uncle I want to purchase a 12volt Warn wench. I would like to run it off a Vector battery start jumper, the kind you can plug in the wall and jump start your battery and carry it around. The guy at the FLAPS said forget it as the 12 volt Warn wench will not run off a batter jump starter. He said that it would not trigger the "demand"??? If you clip the cables to together from a wench or a truck battery how does the portable jump starter know the difference in types of demand? Would not the wench cause a "demand" like starting the truck????? T/C Steve | | | | | Joined: Jul 2000 Posts: 2,192 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,192 | My wench runs on white wine and chocolate.
I know, you mean "winch". Generally, winches draw a lot of power - some as much as a starter motor - you didn't tell us how many amps the one you have draws. Those portable booster batteries are only good for a minute or so of engine cranking.
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Apr 2004 Posts: 543 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 543 | My wench runs on cash and chocolate!
Pessimist - Sees glass as half-empty. Optimist - Sees glass as half-full. Gov't- Sees glass and takes it from you because you have a glass. Political Correctness: A philosophical belief system bereft of common sense and logic, that supports and rewards ignorance and stupidity.
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | You guys beat me to it. I dealt with a few wenches in my life & none required electricity.
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Steve,
Electrical things can be weird. The battery acts like a big sponge so when a charger is attached it senses this load...plus when you hit the starter on the vehicle being jumped, the draw is quite dramatic...several hundred amps at least.
Maybe this is the load the portable jump needs to see before it does something internal or electronic, I don't know. What kind of load does a winch motor see when you kick it in?
Sometimes the fellas at the parts store do know who's on first as they are right where the action happens. Did you 'Google' this question...lots of info out in cyberland.
Stuart | | | | | Joined: Dec 2006 Posts: 1,154 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,154 | HEY THANKS.....OK, bad play on words. I thought it was clever with the Warn product brand.....must have been because got some quick responses!
OK..the jumper states 400 amp starting. I think I will give the Warn Winch people a call and see what they say. We just wanted to make it easier on my UNK we thought he could just plug and play.
My wench is calling me for supper...T/C steve | | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | i doubt the jumper would be able to power it for long. i had a big warn on the bumper of my 66 and it the truck was wired with 2 batterys. it would kill both with thr truck running if i used it for too long. i now use this same winch on my 64 on a wrecker bed i made. so i have to be very careful not to use it too long since i only have one battery, even with the truck running. hr | | |
