7 members (farmallb, Samantha, Opelika Tom, Oswald, Hanks custodian, 2 invisible), 79 guests, and 2 robots.
Topics128,089
Posts1,055,988
Members48,430
#484791 12/21/2008 4:44 PM
I bought an MY6 on ebay, and it was sold as needing a rebuild. I missed that part when I bid, but that's my fault, not the seller's. I pulled the cover off, and can find nothing broken, but there is a lot of wear. As I move the gears around, I can get 4th gear, but that's all. From what I can see, this unit appears to be very simple. With 3 months of winter ahead of us, this is something I would like to try to rebuild myself. Where can I find a manual that would apply to this specific trans? I assume a Mopar 833 manual would be the same as a GM MY6 manual. I have found Chilton and Haynes manuals on the web, but my experience is that those are good for some things, but not for others. Also, where would I buy replacement parts, particularly sychronizers? Thanks in advance for advice, and if this isn't nearly as simple as it appears, please set me straight.
Just trying to help. Try this Link
I've seen some links with info on rebuilding. I just tried to google them and didn't get what I wanted. You might try doing a search here and on Inliners.org, which is were I saw them. I picked up my rebuild kit from a dealer on ekbay. I haven't installed it yet so I don't what quality is. The dealer seemed knowledgeable and also supplied the correct speedo gear for my rear axle gears.
Larry
I don't own a vehicle that isn't old enough to drink.
I just bought parts from Novak Transmissions. Give them a call and see what they can do for you. Check the links for their site.
1946 1-ton Panel
1952 1-ton Comml. W/Grain Body
