| | | Forums66 Topics128,162 Posts1,057,040 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2006 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 35 | I want to swap my 4 speed 410(straight cut gear) out of my 1946 Stock Chevy 1/2 ton with a sm420 (synchro-mesh) out of a 1950 donor. The 420 is 2 inches longer, so some modifications are necessary. Anyone out there done this before? I would like to keep the torque-tube setup. All replies are welcome. 46possum | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I've heard of it being done, but never done it myself. Keep in mind that you need to change or modify the bellhousing because the hole isn't the same size. There might be enough slack in the telescoping joint of the driveshaft to use it, or you could just swap to an AD rear end.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | I have done it and am pleased with the results. 4 on the floor is right. You will need a different bell housing that will accommodate the pedals. Got mine through Jim Carter. I also had to get a starter that fit the new bell housing and the existing flywheel.
I have an open drive shaft so I had my front drive shaft shortened. I don't have anything to help on the torque tube other than swap it out. You could also get a better gear for the diff. if you did this.
I just changed a SM 420 with a torque tube end to an open shaft end with a couple of Novak parts. They may be able to help you on this, at least with parts.
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | |
