4 members (lumbersawyer, Hush, 2 invisible),
64
Mod | | | Forums66 Topics128,026 Posts1,055,407 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 180 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 180 | I am looking for parts for a 40 cab and all the catalogs list parts for 41-46. very few offer parts for a 40. what is the difference if any in theese cabs | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | 41 cab is about 2 inches longer than a 40 cab. Dashes, doors, windshields, interior tin, and rocker panels will all interchange.
What specifically are you looking for? | | | | | Joined: Dec 2007 Posts: 180 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 180 | lower door patch panels and I need to repair the rear window flange on the bottom due to rust. | | | | | Joined: Dec 2007 Posts: 180 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 180 | 41 cab is about 2 inches longer than a 40 cab. Dashes, doors, windshields, interior tin, and rocker panels will all interchange.
What specifically are you looking for? where did they get the extra length from? the cowl? thanks | | | | | Joined: Nov 2004 Posts: 338 'Bolter | | 'Bolter Joined: Nov 2004 Posts: 338 | Door patch panels will be the same, get them from wheelwright you won't be disappointed. He has them on e-bay off and on but he's a bolter so you send him a PM.
The rear window is going to be difficult but there is no difference there.
The extra length is in the floor. You'll find that the floor pan will not interchange.
| | | | | Joined: Dec 2008 Posts: 2 New Guy | | New Guy Joined: Dec 2008 Posts: 2 | Will a 1940 front clip work on a 1941 cab? | | | | | Joined: Nov 2004 Posts: 338 'Bolter | | 'Bolter Joined: Nov 2004 Posts: 338 | Don't know about that one. I believe the hoods are different but I've never tried to put one of my 40s on a 46.
| | | | | Joined: Mar 2002 Posts: 553 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 553 | 41 cab is about 2 inches longer than a 40 cab. Dashes, doors, windshields, interior tin, and rocker panels will all interchange.
What specifically are you looking for? where did they get the extra length from? the cowl? thanks The firewall is pushed foward about 1 1/2". The cowl and everything else is the same. | | |
