1 members (qside), 72 guests, and 2 robots.
Topics128,049
Posts1,055,741
#482106 12/14/2008 4:19 PM
I am looking for parts for a 40 cab and all the catalogs list parts for 41-46. very few offer parts for a 40. what is the difference if any in theese cabs
1950 custom streetrod build
http://67-72chevytrucks.com/vboard/showthread.php?t=296770
71 corvette conv, 525 hp big block
41 cab is about 2 inches longer than a 40 cab. Dashes, doors, windshields, interior tin, and rocker panels will all interchange.
What specifically are you looking for?
lower door patch panels and I need to repair the rear window flange on the bottom due to rust.
where did they get the extra length from? the cowl?
thanks
I
I Offline
Door patch panels will be the same, get them from wheelwright you won't be disappointed. He has them on e-bay off and on but he's a bolter so you send him a PM.
The rear window is going to be difficult but there is no difference there.
The extra length is in the floor. You'll find that the floor pan will not interchange.
Will a 1940 front clip work on a 1941 cab?
I
I Offline
Don't know about that one. I believe the hoods are different but I've never tried to put one of my 40s on a 46.
I know the Front fenders are different too, but I just saw a comment in another thread saying it will bolt up the the 41 cab -
https://www.stovebolt.com/ubbthread...lat&Number=475541&gonew=1#UNREAD
thanks
The firewall is pushed foward about 1 1/2". The cowl and everything else is the same.
