1 members (homer52),
256
0
Mod | | | Forums66 Topics128,101 Posts1,056,180 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 36 | anyone know what range of years steering columns were the same in 2nd series chevy ie what years will fit in a 59? | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | steering wheels are 57-59. Steering box rebuild kits are 55-59, bearings 55-59. Cabs are the same so lengths should be same. My guess: all columns 55-59 will fit and maybe some in the 60's?
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the 55/6 column is a few inches longer than the 57-9, which was shortened to accomodate the dished steering wheel ... still interchange tho .... the longer early column will cramp some folks with the dished wheel, the 55/6 wheel on the shorter late column gives a bit more room for bigger middles  Bill | | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | The '55 and '56 columns will be a few inches longer. They went to a deeper collapsible wheel in '57, so the columns were shortened. | | |
