7 members (WICruiser, Peggy M, 55shaker, Hotrod Lincoln, Steelonsteel, TS3600, GRNHydra), 124 guests, and 3 robots.
Topics128,141
Posts1,056,470
Members48,441
Junior Member
Junior Member
So I sent the truck project I started three years ago back to the shop to be finished. The owner says I may need to shell out some big bucks to get some brackets that will address my problem....I guess my old block (late 50's or early 60's) does not have certain holes for mounting up all the correct brackets. I'm told that a long water pump would solve everything but then It would hit my radiator so thats not an option. Any suggestions no how to line everything up on an old block? wink
You can get a high mount alternator bracket that mounts the alt. off of the water pump and intake for about $50. You can get a P/S bracket setup for about the same money.Check with your local hot rod shop and ask about plain steel, that's where you save the money. I bought mine at a Goodguys show for $39.95. Later
Dave
Even a blind squirrel gets a nut sometimes!
As most hot rod builders know...Allen Grove is the "go to guy" for a lot of brackets. If you don't see what you need call them, they can usually help.
www.allengrovecomponents.com
Beltfed
I'm running a mid sixties 327. Alternator brackets I have mount it high on the right side - bolts to the water pump and intake manifold. Made by Bill's Hot Rod parts in LA. I think he also has brackets for AC if you are interested.
1940 Chevy KC 1/2-Ton
Sorry for that miss spell, Bill is correct.
Junior Member
Junior Member
That all really helps I think my mechanic said Bills was the place to go . I've got the alternator figured out as I purchased a big arm to hold the top of the alt and the piece it pivots on is bolted to the headers. The main issue is the PSteering unit lining up with everything. I'll give them a call and see what they can come up with. I just dont want to spend hundreds on a billet system....ich! I'll let you know how it works out. -Mike Gardner
Junior Member
Junior Member
