1 members (MickeyP), 110 guests, and 3 robots.
Topics128,193
Posts1,057,253
Members48,466
Hello,
I'm thinking about going with an Edelbrock performer on my 350 in my '85 'burb. Questions: how much CFM? Do I need an intake manifold too? Will I have to change the distributor? What about the computer controls? How do I go about setting this up? Does anyone have links to any articles/books/instructions for this type of thing? Thanks for all the tips and advice!
Tyler
1953 3600 Pickup
1946 Fleetline Aerosedan
1948 Hudson Commodore
If the engine is stock, a 500 to 600 cfm carb will be plenty. As far as the intake manifold is concerned, an aftermarket intake will give you a little more power and perhaps slightly better fuel mileage, but it is not necessary that you change the manifold. You will not have to change the distributor or computer controls. Edelbrock makes carbs and intakes that are compatable with computer controlled vehicles (i think).
Phil
Never hold your farts in. They travel up your spine and into your brain...that is where crappy ideas come from.
I just put an Edelbrock 600 on my friends 86 K-10 with a 350/700R4. It has the stock intake and ignition. It runs great. It's a pretty straight forward swap.
V
V Offline
Spend the extra $$$ and get the Edelbrock Quadra jet carb they will get better fuel milage than the AFB type and will be a direct bolt on replacement for your stock carb assuming you have a Q jet on it now.
Riding in the Passing Lane
If you have a o-drive trans. you must get the trans. cable hooked up & adjusted correctly or the trans. will be short lived. You will need to change the dist. to one with mechanical advance & vacuum advance. The computer needs feedback from the carb. to work the spark advance.
1972 Chevy c10 Cheyenne Super
If you go with the Qjet style Edelbrock you can use the stock trans cable/bracket etc. Its patterned after the late model Qjet from GM. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
Tab Offline
If you install this 4bbl you will need to run headers and free flow exhaust in order to achieve the motors full potential.
But this is a stovebolt forum. There are thousands of Chevy 350 hop up sites on the net.
delete my account and pictures
Tab Offline
Thanks for the tips, guys. Tab, I'll check out those links you posted. I'm sorry to "pollute" (pun intended!) the stovebolt pages with questions about POS mid-80's smallblocks. However, I'll never feel guilty about the pollution that comes from my vehicle, or the poor fuel economy, because it's MY car and MY money, and MY choice.
Regards,
Tyler
1953 3600 Pickup
