9 members (Gdads51, 52Carl, fonz8261, greenie-reddy, 2-Ton, Forty9, RoadsScholar, mk72, 1 invisible),
138
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,125 Posts1,056,343 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 493 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 493 | Some of you electronic wizards take a look at this link. http://www.datasheetcatalog.org/datasheet/microchip/21483b.pdf figure 7.2. I am still looking to convert the t-5 output pulse to drive a DC motor. I would have to amplify the output to drive the motor but this looks like it may work. Any thoughts. I really don't want to spend the $300 for the cable-x deal. | | | | | Joined: Nov 2005 Posts: 238 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 238 | I'm not an electronics expert, but I think that you might struggle to get the exactly linear speed response you'd need from a DC motor as the voltage increases. You'd need this to get an accurate speedo reading throughout the range rather than at just one point.
If you can't adapt the T5 you have to a gear driven speedo setup, it should be possible to rig up a lightweight belt drive for the speedo using the the transmission slip yoke as a driving pulley. Lots of early European cars used this type of setup to drive a speedo cable via a driven pulley mounted alongside the transmission. A lightweight round section belt is all you'd need, it's not really transmitting any power.
Stuart.
| | | | | Joined: Jan 2008 Posts: 493 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 493 | I never thought about a manual drive off to the slip yoke. That may be an option to play with. | | | | | Joined: Mar 2008 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2008 Posts: 60 | I'm going to use a programmable electric speedometer in place of my old speedometer. You could waste a lot of time just getting a speedometer to read right. | | | | | Joined: Jan 2008 Posts: 493 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 493 | I like the look of the gauges that came with the truck. They just scream 1950's design. I got two of the chips to play with if it looks like it isn't going to pan out I will just order the cable-x. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If you put a speedo gear on the shaft you have to change the rear houseing also. You can use one from a T-4 by changing the detent plate. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | The T4 rear housing doesnt have the pocket for 5th gear t5's T4 However you will have to either swap the rear housing or fabricate a sleeve for the mechanical speedo drive to fit in the larger hole for the magnetic pickup.
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I took the selector plate out of the T-4 & put in the one from the T-5. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
