7 members (Guitplayer, Peggy M, Hotrod Lincoln, Maybellene, Jaison, 55shaker, Gray_Ghost),
65
Mod | | | Forums66 Topics128,076 Posts1,055,922 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 12 New Guy | | New Guy Joined: Nov 2008 Posts: 12 | I have a 66 c10 with the 283 I am looking for information on how these came from the factory regarding the top radiator hose. I have been told that these had a metal pipe for a radiator hose with rubber fittings on the radiator side and the thermostat side. If someone had a picture they could post here that would be helpful to me also. If in fact this was the way they came from the factory someone changed my top to an all rubber hose and discarded the original pipe. Are these pipes made aftermarket anymore? Thanks Chris | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I could be wrong (just ask my wife) but I believe both top and bottom were rubber.
~Jim
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | As far as I know, it should be an all rubber hose. About the only engine with the setup you describe was the old ford Flathead V8.
Bill Burmeister | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | As far as I know, it should be an all rubber hose. About the only engine with the setup you describe was the old ford Flathead V8. Right and my Ford tractor.
~Jim
