1 members (Cosmo), 84 guests, and 3 robots.
Topics128,054
Posts1,055,779
#481894 12/14/2008 12:09 AM
I ordered a spring shackle kit from one of our linked parts suppliers for the front of my 39. This should be the same kit for 39 through 46. After pressing in the four shackle bushings, I discovered that the shackles would not work because the holes were oversized and not tapered where they fit on the pins. Thought I would use the old shackles and discovered that the pins/bolts also had the wrong taper (no shoulder) allowing the shackles to press on too far, not leaving room for the rubber/cork seals.
Not wanting to press out all of the bushings I tried to cut my losses by ordering new pins from NAPA (1954 ½ ton). The pins are supposedly the same from 1939-54. Wrong again. Perfect taper and shoulder but approximately ¼” to long.
Chevys of the 40’s has a shackle rebuild kit (no shackles) that contains just the pins, bushings and seals. Maybe the third time could be the charms but have my doubts. This is getting to be a major time and money expense for what should have been a simple project (typical). Anyone else have a similar problem and know of a solution? The GM parts book shows that the pins and bushing for the front spring shackles the same for 1939-54.
i put springs and shackles front an rear in my dad's 40 1/2 ton ,i got the shackles from triangle flag and the were exact fit tapered bushing's with the correct seat's in the side bar's ,they came with the side seal's and correct grease zirk's ,carriage type through bolts also .i cant remember the part number's i will try to look them up .you had to have a old parts book to find them ,or a old part's man .i got them from tim at heritage spring . Heritage Spring Service
1001 W Locust St
Bloomington, IL 61701
Business Summary
Contact Heritage Spring Service
Phone: (309) 828-0400
Business Profile for Heritage Spring Service
Services:
Contractors Steel Fabrication & Fabricators & Erection & Erectors
Trailer Hitches
Springs Auto
Machine Shops
Hydraulic Equipment Service & Repair
Drive Shafts
i found the part number'sthe front was cs712 and the rear was cs588
