0 members (),
170
7
Mod | | | Forums66 Topics128,078 Posts1,056,035 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 117 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 117 | I am thinking of powder coating my frame, bumper brakets, spare tire holder on my 46 chev pu is this a good idea or not | | | | | Joined: Dec 2004 Posts: 425 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 425 | Go for it. The electric charge will get the powder in every little nook and cranny, and put it there evenly. If there are any draw-backs, someone will post them. | | | | | Joined: Feb 2007 Posts: 434 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 434 | Supposed the be the best way to do it, if you can afford it.
R-Bo
1959 Apache 1/2 ton Big Window, Short bed Fleetside (under reconstruction) 1966 GMC 305V6 in the family
| | | | | Joined: Aug 2008 Posts: 10 New Guy | | New Guy Joined: Aug 2008 Posts: 10 | My local powder coater told me you need to break sharp edges or you can get gaps. I'm not sure how significant a problem it is though, maybe an expert can speak up? | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I had my frame and a bunch of brackets powder coated. First they were sandblasted: http://rides.webshots.com/photo/2858777480080251109QvHMaJThen coated: http://rides.webshots.com/photo/2606792970080251109wxkOTlI would advise you to clean every speck of grease off the frame before sending it to the blaster (or blasting it yourself) Also look the entire frame over many times, on different days, looking for any imperfections. You have to fix everything before it's coated, or live with it once it's done. Don't get in a rush, take the time to replace the broken rivets, weld the cracks and gouges, and knock out the dents all before you get it coated. I was not told to break sharp edges. But the nature of the powdercoat is it does not want to cover outside corners or inside cracks/corners. Even so my frame was very nicely coated, could be some folks do a better job than others. Grigg | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | Sandblasting is sufficient to remove the burs on the edges of the frame. Powder is a great way to finish a frame.
| | | | | Joined: Oct 2008 Posts: 321 'Bolter | | 'Bolter Joined: Oct 2008 Posts: 321 | I've never looked into it before, but what's the average cost of having a frame powder coated?
1963 Chevy C20 Longbed Stepside 1978 Chevy K30 Custom Deluxe
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I paid 650 for powdercoating my approx 18' long 2 ton frame, as well as a bunch of other parts, all as seen here: http://rides.webshots.com/photo/2858777480080251109QvHMaJI also paid 350 for sandblasting the same, probably could have found a better deal on that part.. Sandblasting is the same expense for either painting or powdercoating. The part to consider is the cost of good primer, paint and labor as compared to the powdercoating cost. When I did my frame I decided powdercoating was cheaper, and a better final product, also easier for me to do/have done for me. Grigg | | | | | Joined: Nov 2008 Posts: 117 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 117 | Thx everyone for your thoughts forgot to mention l was also thinking of doing the wheel rims also anyone every done that | | | | | Joined: Sep 2007 Posts: 29 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 29 | YOU CANT TOUCH UP CHIPS.WILL CRACK AROUND BOLT HOLES IF NOT TIGHTEND CAREFULLY. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Hold on now-- no need to yell, I haven't had any problems with my powdercoat chipping, but true you can't touch up with powdercoat, but you can with paint if needed. I think for a frame and wheels powdercoat is still a good idea. My wheels use clamp plates to distribute the clamping pressure from the lug nuts, so no need to worry about the wheels chipping. http://rides.webshots.com/photo/2317319550080251109EeoORcI did have the plates powder coated too, and so I wouldn't have any problems I used a countersink of the proper angle to cut the powdercoat out of the clamp plates so the lug nuts would have good contact. The clamp plates are quite hard and the countersink did not cut the steel at all, just cleanly removed the powdercoat and stopped. This same method could be used or ordinary wheels to clean the powdercoat out of the lug holes if you thought this was a problem or thought they would chip. Grigg | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | if you can afford it.
but that may not be a bad idea in BC
i did my rims in black @ $50.ea. blasted & powdered.. wish i had done them in another color so the pin-strip would show better. ALL the above answers are very good. it's your truck. me, i finally said because I have soooo much to do and these bolts are not my prized projects, sorry guyz .... if i could cover them w/ a good clean product (i used por-15 on my frame and many other parts ) to protect them until i can't ( afford to ) drive anymore that's where i stopped the buck. It's just a daily driver for fun, not a prized show rig. it should last me until age 75-80. hell w/ the factory paint lasting this long, We're good.
my .01
WHAT EVER you do... grind every spot where your ground wires go and coat that spot w/ a battery (like NO-OX) coating or vasoline for protection. bad ground will accelerate any corrosion, even at the positive connections.
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Nov 2008 Posts: 293 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 293 | I had done a Frame off on our 60 Corvette, and I was up in the air as to paint or powder coat the frame. Here in southern California where nothing related to cars is cheap, it was less expensive to get the job blasted and powder coated than to paint it myself ( the same company did the blasting and powder coating). On a down side, the powder coat is thick, so you will need to clean out all of your threaded holes, close fit areas, etc. afterwards. This mostly seems to apply in the front suspension area. Upside, when it gets dirty, a rag with a little simple green and water on it, and it just wipes off. A word of caution ( from experience ), if you get your wheels done, be sure to clean ALL of the paint, powder coat etc. from the lug nut holes down to the bare metal, or they will continue to come loose on you. I'm not 100% sold on powder coat, but if I was to do another frame off, I think I would still go that direction. | | | | | Joined: Dec 2004 Posts: 425 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 425 | Guys, it IS possible to touch up powdercoating- my friend that is a PROFESSIONAL at it says so... He mixes up the powder with some sort of chemical... goes on with a paintbrush. I'll have to give him a call later to find out what he mixes the powder with. It works well for chips, probably not for a large area. | | |
