13 members (klhansen, Gdads51, tclederman, qside, Hanks custodian, mick53, 1955 1 Series, ShopRag, dt235sd, Barnfind49, Dennys28, 55shaker, baldeagle),
122
Mod | | | Forums66 Topics128,268 Posts1,058,384 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 84 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 84 | I was wondering if there is any information on installing the 3 point seat belts on a '66 fleetside. The sellers informtaion is very sketchy for that year. Do I have to weld something for the shoulder part? I know it is double walled so it won't show on the outside, but I don't know what to do on the inside for this. The floor parts are easy but not up on the cab. Unfortunately, I have finished the truck before I thought about this all important safety matter. Any help or websites is appreciated Gary
GS
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I don't know how much help it will be on a '66 but here's how I did my '56. It might give you some ideas. | | | | | Joined: Feb 2002 Posts: 2,898 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,898 | If I recall from my reading about these old trucks, the original 3 point factory belts had two buckles. The shoulder strap did not retract, I do not believe. The shoulder and lap belt each had a buckle. some aftermarket options: -- on my '65 c10, I used a 3 point kit from Juliano's for the bench seat: http://www.julianos.com-- I have read about other folks using a kit from this place with good results: http://gemstreetrods.com-- -W | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 |
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Oct 2006 Posts: 84 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 84 | This is good information. Looks like I have some fab work to do come spring. I appreciate all. Gary
GS
