1 members (stlcardinalsguy), 71 guests, and 1 robot.
Topics128,030
Posts1,055,430
Members48,422
#48186 07/26/2005 2:06 AM
I want to make sure my trans. is in good shape before driving much. however, my manual (on CD) is not too helpful.
First I need to identify which trans. I have. It is a manual 4spd on the floor of my 66 Chevy truck (w/292). Is there only one of these? That would be too easy. grin
Next, I need to find out how to check the fluid level. I'm assuming there's a plug somewhere on the top kinda like the drain plug on the bottom. BTW, I've got a huge 'protective' layer of grease ALL OVER it. I really need to make sure it is up to snuff before I drive it to the car wash to clean it off. Thanks all.
Oh, and once I find the fill plug, what's the procedure for checking the level? I'm used to having a dipstick to check it. No, I'm not the dipstick. :rolleyes: Then on the other hand, maybe I am. grin
Rance
PS: I've already looked through this page with no luck.
66 C10 FS/LB 292/4-spd manual (I also enjoy Hang Gliding)
I'm too sexy for my hair, that's why it isn't there
#48187 07/26/2005 3:36 AM
That transmission is probably the SM-420, which was used about 3 days past forever in the 3/4 and 1-ton trucks, and several other applications. There will be a pipe plug about halfway up the passenger's side of the case that's both the fill point, and the level plug. Remove the plug, and, if necessary, add 90 weight gear oil until the level is even with the bottom of the hole. Reinstall the plug, and drive on.
#48188 07/26/2005 12:31 PM
I searched the net and found some pics of the SM420. Yep, that's what it looks like. Thanks Jerry, exactly what I needed.
Rance
#48189 07/26/2005 1:30 PM
Does this help? It's a SM420 from a big bolt.
Peg
~ One of many.
