Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
0 members (), 49 guests, and 2 robots.
Topics128,009
Posts1,055,293
Members48,419
#4813 03/14/2003 7:46 PM
Got another question for the driveline gurus...
I'm building a 350 v8 for my 1950 AD truck. I plan to bolt a TH400 automatic tranny to it (the rear has already been swapped for a unit with better highway gears).
It appears there are 2 different sizes of flexplates available for my engine and I'm not sure if only one will work for my plans, or if either will. It appears there's a 14" diameter unit with 168 teeth and a 23-3/4" diameter unit with 153 teeth.
My question is, which one should I install on my new engine?
Thanks for any and all replies!
Tom
#4814 03/14/2003 7:48 PM
Oops ... typo... the other option is a 12-3/4" flexplate ... not 23-3/4".
I guess I proof-read it just a little too fast.
Sorry folks!
Thanks again for any replies!
Tom
#4815 03/14/2003 8:25 PM
Which one is easiest and cheapest to get replacement parts for?(torque- convertor,,starter etc.)
#4816 03/14/2003 8:31 PM
Use the one that is compatable with your tranny, torque converter and starter. Also specify year of engine, as that can clear it up too.
chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#4817 03/14/2003 9:10 PM
I havn't purchased the tranny, torque converter or starter yet. I wanted to make sure I didn't buy something incompatible with my goal of 350 v8/TH400 combo.
My engine is a 1970 Chevy 350 4 bolt main.
Thanks again!
Tom
#4818 03/17/2003 2:27 AM
The 168 toother uses an offset starter bolt pattern.There is one that has all 6 bolts on the same circle,those are for truck turbo 400 and Allison 540-5 series.And there is another common one that has both bolt patterns on it,it uses 3 or 3 bolts,depending on convertor.
#4819 03/17/2003 2:42 PM
Thanks for the replies!
I bought the 14" flexplate with 168 teeth and drilled for 10.75" or 11.5" converter bolt pattern.
