5 members (ShopRag, kurbside bolter, Ponchogl, cmayna, 1955 1 Series), 107 guests, and 4 robots.
Topics128,268
Posts1,058,375
Members48,485
#48132 07/25/2005 12:58 AM
Here's the story. Last October the truck,'51 GMC, was running just great then my crankshaft broke. HAd the engine out had all the work done and re-installed everything. Know I am getting a vibration at about 40mph. Tires are good king pins are new etc..
Here is my thought and give me your thoughts.
I kind of remember when I put the drive line back together that the ball
housing on the rear U-joint went together pretty tight. I mean I really
had to torque the bolts down on the "ring" that holds the ball into the
"socket". I did this because I used Permatex to make the seal. But I am
wondering if I way overdid it. Is this part suppose to have some flex to
it?
Also I did a Search and one comment that came up was "u-joints being "out of phase". Since I have a longbed does this mean both u-joint have to be lined up?
#48133 07/25/2005 1:37 AM
Junior Member
Junior Member
Thomas did you install a new clutch, when you had the motor out, if you did did you line up the marks on the fly wheel and the clutch? I learned the hard way.
I've never been lost just confused for a month or two. 1950 & 1952 chev. 1998 Chev 4x4.
#48134 07/27/2005 7:46 PM
In my manual for a '79 GMC w/two piece drive line, they say to mark the spline so that it is installed in the proper "phase". Not sure what that means, but they said it would vibrate if it was out of phase. Good luck.
#48135 07/28/2005 2:43 AM
V
V Offline
U joints out of phase shouldnt be a problem on torque tube since it only has one
#48136 07/28/2005 3:10 AM
Tab Offline
My truck had a vibe that drove me AND my mechanic nuts. He started dismissing my bitching about it. THEN I took my truck down to his shop, jacked up the rear, took the tires off started it up and ran through the gears while he looked underneath. (I removed the tires to eliminate them as a source of the vibration.) Turns out it was the trans output bushing. They screwed up the installation. VINDICATION.
delete my account and pictures
#48137 07/28/2005 7:48 PM
Quote
A while back I had to replace the main bearing between my two piece drive shaft. they rebuild the shaft and balanced. I didn't mark the spline, followed the advise on putting the two pieces together and to this day I still have a vibration around 40mph. I tried several different settings with no improvments. Don't know how to fix but maybe thi is your problem.
..Russ
1960 Chevy Apache (C10)
1965 Chevy C30 Dump Truck
1966 Chevy C30 Tow Truck
#48138 07/29/2005 3:22 AM
Is this a long wheel base truck with the short stub shaft between the trans and torque tube with two "U" joints?
My Blog
#48139 07/29/2005 3:58 AM
Could someone explain the phase thing please?
And how would you know if had already been put back together by someone else incorrectly in the past?
Thanks,Jeff
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
#48140 07/29/2005 6:19 PM
Yes, This a Long bed '51 GMC. It has that short section of shaft.
#48141 07/29/2005 8:51 PM
[img]http://www.chicagolandmgclub.com/driveline/0404/u-joints.jpg[/img]
Sorry for the big picture. It's the best one I found.
Slipe the joint apart and turn either end 90 degrees and it would be out of phase.
'67 GMC 3/4 292 4spd
#48142 07/30/2005 12:03 AM
Thanks Richard.
Jeff
1957 GMC 150
#48143 07/31/2005 4:43 AM
It is posible you put one of the U joint end caps on backwards, the ones that have the mounting bolts going through them. The bevel side goes on first.
My Blog
#48144 07/31/2005 8:32 AM
Thomas
I'm not familiar with your model truck but I have a WW2 Jimmy .These trucks all have several conventional driveshafts but also one, 2-piece driveshaft with a carrier bearing between.On normal 1-piece driveshafts the two inner yokes are assembled in line,and the two outer yokes in line;as in Richard's picture; but on the two-piece shafts, the two uj's on the front shaft are assembled at 90 degrees to each other to eliminate vibration.I don't know the principle behind this but the Jimmy manual gives specific instructions about it and also specifies that this is only for this 2-piece shaft.I can e-mail the pages if you are interested. I know this arrangement is still used today by at least some manufacturers.Hope this is of some help!
#48145 07/31/2005 8:51 PM
I would have to see the wording or the pictures.
It should be noted that on a two piece driveshaft that has three "U"(universal) joints the 1st U joint and the 2nd U are in phase. At the same time the 2nd U joint and the 3rd U joint are also in phase. The 1st U joint and the 3rd U joint are therefore, 90 degrees out of phase.
If any one of those three U joints is a constant velocity joint, that changes everything.
