1 members (Rnl364),
104
Mod | | | Forums66 Topics128,077 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 95 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 95 | Among the parts I must locate for a trans swap in my 65 suburban (4 on floor to th400 automatic on column) is the trans crossmember. I've been told I need to change it out to an automatic style, but is a PG trans crossmember the same as a TH400 one? As you all probably know, early th400 stuff is not so easy to find. | | | | | Joined: Nov 2008 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 48 | I am undergoing a similar swap on my '64 Stepside. We have a '66 donor truck with the power glide, but I will be using the 700R4 in our '64. I was under the assumption that they would be the same. They were not. I am not sure about a Suburban, but you can buy one for a C-10 or C-20 in that year allready built for as little as $79.95 + S&H . As for me, I am building my own super hevy duty version! I would tend to think the Suburban and pickup would have the same frame. But I am not shure on that. Good luck !
tp://s367.photobucket.com/albums/oo113/RED64STEPSIDE/
| | | | | Joined: May 2005 Posts: 119 Shop Shark | | Shop Shark Joined: May 2005 Posts: 119 | I could sure use the shift linkage (part from the frame to the trans) or a picture of it so I could maybe fab one myself. I have 305-v6 with powerglide '66 GMC. I made one myself but it will only go into drive not 1 or 2. Ted. | | | | | Joined: May 2005 Posts: 119 Shop Shark | | Shop Shark Joined: May 2005 Posts: 119 | Sorry oem4me, didn't mean to draw of your subject. | | | | | Joined: Aug 2008 Posts: 230 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 230 | hey oem4me some time's mid 70's chevelle cross members make a good platform for the older truck's I've got one in my dad's 40 1/2 with a few modifications . | | |
