9 members (Wally / Montana, UtahYork, Frank50, BarryP, BC59, cmayna, DadsFirstPickup, Gray_Ghost, 1 invisible), 125 guests, and 2 robots.
Topics128,134
Posts1,056,740
Members48,454
Junior Member
Junior Member
Would there be any problem swapping a 55.2 1/2T Chev front-end(which is good shape) into a 49 1/2T Chev(which is shot)? I-beam and leaf springs, etc. look similar, is width the same?
Thanks. Oh, each is 6 lug. I know the shocks are different.
Do it cool
better brakes and better availability of brake parts.
Only thing to look for that I remember is the difference in the drag-link ends(from steering box to steering arm at wheel)
Junior Member
Junior Member
Mechaniac, thanks.
You're right bendix type instead of huck. will get out there tomorrow and check out drag link situation, i've got the entire steering gear, maybe the whole thing swaps.
