4 members (Bills54, Nick in Manitou, Bill Hanlon, Stovebolt48), 73 guests, and 2 robots.
Topics128,035
Posts1,055,559
#480877 12/11/2008 3:50 AM
1 Offline
Been runnin the truck every couple of days (whenever i can!) and he runs great. The smoke has almost completely diminished, it tends to have weird little spurts of it, but even when it does smoke for a little bit, it's NOTHING like at first. It's obviously blue oily smoke, although it smells more like gas. But see through and almost unnoticeable nonetheless. I've got three questions.
1.Can i get a ballpark guess on the average time it takes for new rings to seat completely?
2. I have to replace the oil pan gasket and therefore change the oil anyway, but is there a possibility its thin from gas getting in it right when we first started running it (maybe causing some of the early on problems)?
3.Is it ok to use that stuff at auto parts stores that says it helps rings seal. I forgot who makes it, but there's also another supplement made by Bar Leak's called Smoke Away or something, supposed to put it in your oil. I dunno, seemed like a good thing to do, just checkin to see what yall recommend.
Preston
3 Speed Or No Speed
1965 Chevrolet C10 Stepside
Great to hear things are much better! My opinion on your questions.
1) Seating the rings will probably take a few hundred miles. Vary your speed & engine RPM for a while.
2)I assume you replaced your pan gasket when you had the engine apart. The excess vacuum from the PCV system had to pull air from somewhere. It probably sucked your gasket in somewhere. Gas in engine oil is not good- change it!
3)I personally would NEVER use most oil additives. All you are doing is masking a problem. Most additives seem to be used as a last resort for someone trying to get a few more miles out of a tired engine. I worked at an engine rebuilder many years ago and hated tearing down an engine someone used "engine rebuild in a can" in.
Dave
66 GMC- father /son project with the "GMC KID"
36 Chevy PU- 4x4 lifetime project
64 Skylark- wife says its hers
dave64 #480917 12/11/2008 5:41 AM
1 Offline
So if my compression is 90-90-100-100-110-100 but ive only driven 40 miles, you think the comp. will increase some more?
3 Speed Or No Speed
