| | | Forums66 Topics128,049 Posts1,055,693 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2007 Posts: 35 | Hello, after a year of working on the mechanicals on my 56 3100 w265 V8, now its time to start working on other areas. I bought new door hinge pins because it was obvious they were wore out. While unbolting the lower hinges on both sides the bolts just spun and would not come out. I ended up cutting through from under the cab in the wheel well to find that the cage that holds the nut was rusted out. Now I need to find parts to replace those and the holes I had to cut open to get to them. Any suggestion on where to get those caged nuts? Also what can I spray in those areas before patching the holes to stop the rust? | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | I'm not familiar with the way your '56 is built but I just welded regular nuts in place of the ones were stripped in mine. You may have to do some surgery to get to them but that's part of the fun... yea, right As for rust treatment, I'm sold on Eastwood's rust treatment products and they just released their RUST CONVERTER in an aerosol. I'd recommend that. | | |
