2 members (FAST55, Rusty Rod), 96 guests, and 2 robots.
Topics128,026
Posts1,055,404
Members48,422
#480538 12/10/2008 4:05 AM
i have 235 12v i just got to run, on the slenoid the large center post has the bat connect, the right sside i am jumping to start, what is the left side post for,any clarity would help thanks 2tired
read this as it may help
http://www.misterfixit.com/starttst.htm
some need pictures
http://home.comcast.net/~onovakind67/starterrelay.GIF
http://i147.photobucket.com/albums/r301/David58Bug/StartingMotorTroubleChecking.jpg
Jim & Caroline
trying,
There should be two small terminals. The one you can jump start it with is called the 'S' terminal, and when powered, it pulls the solenoid in and spins the starter, just as you have discovered.
The other little terminal is the 'R' terminal (relay), and it is only powered when the solenoid is in and the starter is spinning. Think of that small terminal as a switched source for 12 volts. It normally would supply ignition voltage when the key is in START.
Does this make sense.
Stuart
thanks for the input,trying
