| | | Forums66 Topics128,026 Posts1,055,406 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2008 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 46 | i have 235 12v i just got to run, on the slenoid the large center post has the bat connect, the right sside i am jumping to start, what is the left side post for,any clarity would help thanks 2tired | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 |
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | trying,
There should be two small terminals. The one you can jump start it with is called the 'S' terminal, and when powered, it pulls the solenoid in and spins the starter, just as you have discovered.
The other little terminal is the 'R' terminal (relay), and it is only powered when the solenoid is in and the starter is spinning. Think of that small terminal as a switched source for 12 volts. It normally would supply ignition voltage when the key is in START.
Does this make sense.
Stuart | | | | | Joined: Sep 2008 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 46 | thanks for the input,trying | | |
