8 members (Otto Skorzeny, 68ironhead, 3B, Jon G, Gdads51, NJC, 2 invisible), 104 guests, and 1 robot.
Topics128,130
Posts1,056,369
Members48,441
V
V Offline
Well I was down to my last box support on my s10 frame. Didnt realise there was a slight gas leak from the one of the lines and and a spark from my welder lit my garage up. I managed to push the frame out but it is not salvageable.
I am picking up a stock frame from a co-worker and what was left of a cab. I was thinking of using a mustang II untill i realised the cost.
Wondering if anyone has used the kits from http://www.welderseries.com/ . What track width should you be using with a 50 ish frame ? What other cars are compatible for the parts I need to complete this ?
. cry
sorry to here this
FIRE EXTINGISHER ?????? at least two in the shop. use an ABC/halon in the truck, no dry chemical
cheap insurance
Jim & Caroline
Fire is bad, sorry you had to go through that.
~Jim
