11 members (52Carl, carbking, Gdads51, Bill Hanlon, 1955 1 Series, 2-Ton, Robert Crandall, fonz8261, greenie-reddy, 2 invisible),
116
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,124 Posts1,056,347 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#4800 09/10/2002 10:35 PM | Joined: Sep 2002 Posts: 9 Member | | Member Joined: Sep 2002 Posts: 9 | I am getting ready to rebuild my 1950 216 and have never done anything like it. I am feeling a little intimidated about the Babbitt bearings. Is it difficult to do in your backyard shop? Or is it best to leave to the experts? | | |
#4801 09/11/2002 12:30 AM | Joined: Mar 2001 Posts: 384 Shop Shark | | Shop Shark Joined: Mar 2001 Posts: 384 | burb-- I have no experience with 216s either but these guys are reputed to be as good as there is with that engine: Becks web page . Gotta be worth a call to see what they are doing and what they recommend. Even if you don't use em their parts may be worth looking at--high pressure oil pump and spin on oil filter.
Buzz'n Half Dozen
| | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Unless you're going for complete originality, I recommend going with the machined insert bearings. You can have yours' machined or make a core swap. Don't know if they're still available, but you could order new from a local parts store.
Fred 52 3600 69 C-10
| | | | | Joined: Jul 2002 Posts: 59 Member | | Member Joined: Jul 2002 Posts: 59 | Here\'s a inexpensive little book that might serve your needs. 72 Sierra Grande - Maych Forget about "do it right the first time". Do it wrong the first time to learn how, then do it right the second time.
| | | | | Joined: Sep 2002 Posts: 9 Member | | Member Joined: Sep 2002 Posts: 9 | Thanks much guys, BECKS looks like a good resource. I am not going for an all original truck, but am trying to stick to it as close as I can. | | |
