| | | Forums66 Topics128,101 Posts1,056,181 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#48011 07/20/2005 7:08 PM | Joined: Mar 2005 Posts: 170 Member | | Member Joined: Mar 2005 Posts: 170 | I getting ready to remove the old babbit pounder from my 1940 GMC and replace it with a fresh 235. I got the radiator out last night, then removed the 4 bolts holding the fan to the waterpump pulley. The fan blades would not come off the pulley. There seems to be a steel ring pressed onto the shaft that is locking the blades onto the shaft.
How do I get the blades off - does this ring need to be cut off some how? There doesn't seem to be anyway to pull it off.
Ideas???
Thanks, Steve | | |
#48012 07/20/2005 9:44 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | It should come off. The pulley does not come off on a chevy but i,m not shure about the GMC although GMC engines are not babbit pounders. Try spraying some penatrating fluid on it & tap it with a hammer or wedge something in behind it. If the belt is still on you can try turning it. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#48013 07/21/2005 3:36 AM | Joined: Jun 2005 Posts: 221 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 221 | it should pop right off but you may need to spray it with some PB Blaster and persuade it with a screw driver or small hammer | | |
#48014 07/21/2005 3:57 AM | Joined: Mar 2005 Posts: 170 Member | | Member Joined: Mar 2005 Posts: 170 | Thanks guys, I'll give it some spray and soak time and try again. BTW, this is a babbit pounder, its a 224, a close Canadian cousin of the 216. Not a 228 GMC engine.
Steve | | |
#48015 07/21/2005 4:50 AM | Joined: Jul 2004 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2004 Posts: 60 | Beat it with a hammer.
1951 3100
#48016 07/22/2005 3:31 AM | Joined: Mar 2005 Posts: 170 Member | | Member Joined: Mar 2005 Posts: 170 | I got it off tonight. Nothing but 65 years of rust and paint holding it on. It just needed a little mroe persuasion.
Thanks, Steve | | |
