3 members (Otto Skorzeny, Pre '68 Dave, BCBill), 289 guests, and 1 robot.
Topics128,101
Posts1,056,178
Members48,436
#48011 07/20/2005 7:08 PM
I getting ready to remove the old babbit pounder from my 1940 GMC and replace it with a fresh 235. I got the radiator out last night, then removed the 4 bolts holding the fan to the waterpump pulley. The fan blades would not come off the pulley. There seems to be a steel ring pressed onto the shaft that is locking the blades onto the shaft.
How do I get the blades off - does this ring need to be cut off some how? There doesn't seem to be anyway to pull it off.
Ideas???
Steve
See my 1940 Canadian GMC:
http://community.webshots.com/user/ndnchf
#48012 07/20/2005 9:44 PM
Riding in the Passing Lane
It should come off. The pulley does not come off on a chevy but i,m not shure about the GMC although GMC engines are not babbit pounders. Try spraying some penatrating fluid on it & tap it with a hammer or wedge something in behind it. If the belt is still on you can try turning it.
1972 Chevy c10 Cheyenne Super
#48013 07/21/2005 3:36 AM
V
V Offline
it should pop right off but you may need to spray it with some PB Blaster and persuade it with a screw driver or small hammer
#48014 07/21/2005 3:57 AM
Thanks guys, I'll give it some spray and soak time and try again. BTW, this is a babbit pounder, its a 224, a close Canadian cousin of the 216. Not a 228 GMC engine.
Steve
#48015 07/21/2005 4:50 AM
Beat it with a hammer. smile
1951 3100
#48016 07/22/2005 3:31 AM
I got it off tonight. Nothing but 65 years of rust and paint holding it on. It just needed a little mroe persuasion.
Steve
