2 members (DennisM, 1 invisible),
80
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,264 Posts1,058,350 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 98 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 98 | what would be the best way to treat my stock rims as far as good durable finish...nuthin fancy, just stock black rims with the dogdish caps.thanks........ Mark | | | | | Joined: Aug 2005 Posts: 6,379 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,379 | I had mine blasted & powder coated. Works for me.
| | | | | Joined: Nov 2008 Posts: 98 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 98 | sounds good to me...thanks! | | | | | Joined: Sep 2002 Posts: 159 Shop Shark | | Shop Shark Joined: Sep 2002 Posts: 159 | I sanded mine, both sides. if the rust is really flaky, use a steel wheel attachment on a drill. i used regualr primer on both sides then black rustproofing type spray paint on the back and a nices body aerosol color you need on the front. its best to do before the tires are mounted
56 stepside 3/4 ton longbed
