5 members (lumbersawyer, Nick in Manitou, Wally / Montana, Sjm, Peggy M), 135 guests, and 4 robots.
Topics128,264
Posts1,058,357
Members48,485
#479209 12/06/2008 4:13 PM
what would be the best way to treat my stock rims as far as good durable finish...nuthin fancy, just stock black rims with the dogdish caps.thanks........ Mark
62 mark #479239 12/06/2008 5:38 PM
Ex Hall Monitor
Ex Hall Monitor
I had mine blasted & powder coated. Works for me.
Tiny #479284 12/06/2008 8:05 PM
sounds good to me...thanks!
62 mark #480021 12/08/2008 10:31 PM
I sanded mine, both sides. if the rust is really flaky, use a steel wheel attachment on a drill. i used regualr primer on both sides then black rustproofing type spray paint on the back and a nices body aerosol color you need on the front. its best to do before the tires are mounted
56 stepside 3/4 ton longbed
