3 members (dt235sd, Gdads51, klhansen), 81 guests, and 2 robots.
Topics128,205
Posts1,057,427
Members48,471
anyone install a toyota power steering box in their bolt. The type that is similar to the stock box, as far as the output shaft coming out horizontally (not vertically like later year boxes as well as 2wd boxes). Im trying to figure out how to mount this and would like to see other peoples setups to help me make a decision.
Thanks!
Hi Chris,
I have some pictures of the Toyota box mount and other related stuff on page 8-9 in my webshots "Tips and Tricks album.
I gleaned the pictures from someone who converted to the Toyota 4wd mid 80's box (mounted in front of the Toyota pickup front cross member) in their AD truck. I've used the Toyota box on a number of straight axle Ford trucks, along with the Saginaw box and the pictures give you a basic idea of the shape of the box mount bracket and pitman arm you'll have to fabricate. The Toyota box mounts in the same position as the stock Chevy box, and you can modify your stock column to maintain a more stock appearance.
Dave
BTW, if you click on "full size" in the upper right corner of the webshots page you can increase the size of the picture.
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
