9 members (55shaker, 1955 1 Series, BC59, 3800GUY, RaNfLaS, tclederman, Otto Skorzeny, wilbur53, FAST55), 156 guests, and 0 robots.
Topics128,104
Posts1,056,201
Members48,436
#479258 12/06/2008 6:27 PM
Apprentice
Apprentice
I have a 1950 GMC and have replaced the wiring harness and added a fuel injected engine. The wiring harness fuse panel, ecm and new fuel injection wiring panel was placed under the seat. Does this location pose any problems with fire safety and if so, other than moving them, what can I do to reduce the safety issue?
Under the seat is a typical location for this kind of stuff. As long as the work was done properly and nothing rubs the wiring I would not see any safety problems.
Any car or truck with power seats, seat belt warning buzzers, seat warmers and other stuff has wiring under the seat.
I see no major problem with it either, other than you will need to amke sure that the seat either has enough space under it or can be tilted up for access fi any maintainance (like replacing a fuse) needs to be done.
Bill Burmeister
Apprentice
Apprentice
Thanks for the infomation. Just thinking of possible problems in the future.
Darren
One thing to consider would be the hole (with a grommet) that is under the seat. I would think that is there to drain water. If water gets in there mucho problems senior.
~Jim
Apprentice
Apprentice
I saw the hole under the seat at the lowest portion. I assumed it was there to drain water in case of water in the cab. The electronics are on the highest portion under the seat but water damage could be a issue. Need to make sure the cab is sealed well.
