8 members (cmayna, Gray_Ghost, Donf, Otto Skorzeny, Gdads51, Jon G, Forty9, Shade Baby), 104 guests, and 0 robots.
Topics128,118
Posts1,056,307
Members48,439
Some of you electronic wizards take a look at this link.
http://www.datasheetcatalog.org/datasheet/microchip/21483b.pdf figure 7.2. I am still looking to convert the t-5 output pulse to drive a DC motor. I would have to amplify the output to drive the motor but this looks like it may work. Any thoughts.
I really don't want to spend the $300 for the cable-x deal.
I'm not an electronics expert, but I think that you might struggle to get the exactly linear speed response you'd need from a DC motor as the voltage increases. You'd need this to get an accurate speedo reading throughout the range rather than at just one point.
If you can't adapt the T5 you have to a gear driven speedo setup, it should be possible to rig up a lightweight belt drive for the speedo using the the transmission slip yoke as a driving pulley. Lots of early European cars used this type of setup to drive a speedo cable via a driven pulley mounted alongside the transmission. A lightweight round section belt is all you'd need, it's not really transmitting any power.
Stuart.
I never thought about a manual drive off to the slip yoke. That may be an option to play with.
2 Offline
I'm going to use a programmable electric speedometer in place of my old speedometer. You could waste a lot of time just getting a speedometer to read right.
I like the look of the gauges that came with the truck. They just scream 1950's design. I got two of the chips to play with if it looks like it isn't going to pan out I will just order the cable-x.
Why don't you put the mechanical speedometer drive gear in your T5 and be done with it?
It's been done before, as seen here:
http://oldgmctrucks.infopop.cc/eve/forums/a/tpc/f/633004236/m/4141096923?r=5971090133#5971090133
If you're not a member of oldGMCtrucks.com http://oldgmctrucks.infopop.cc/eve you may have to sign up
Seems the problem is the shaft doesn't have a place for it, but some epoxy solves that.
What do you think?
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
Riding in the Passing Lane
If you put a speedo gear on the shaft you have to change the rear houseing also. You can use one from a T-4 by changing the detent plate.
1972 Chevy c10 Cheyenne Super
The T4 rear housing doesnt have the pocket for 5th gear t5's T4
However you will have to either swap the rear housing or fabricate a sleeve for the mechanical speedo drive to fit in the larger hole for the magnetic pickup.
I took the selector plate out of the T-4 & put in the one from the T-5.
