1 members (Rusty Rod),
80
Mod | | | Forums66 Topics128,127 Posts1,056,680 Members48,452 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2003 Posts: 28 Junior Member | | Junior Member Joined: Aug 2003 Posts: 28 | Would there be any problem swapping a 55.2 1/2T Chev front-end(which is good shape) into a 49 1/2T Chev(which is shot)? I-beam and leaf springs, etc. look similar, is width the same? Thanks. Oh, each is 6 lug. I know the shocks are different. | | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Do it better brakes and better availability of brake parts. Only thing to look for that I remember is the difference in the drag-link ends(from steering box to steering arm at wheel)
| | | | | Joined: Aug 2003 Posts: 28 Junior Member | | Junior Member Joined: Aug 2003 Posts: 28 | Mechaniac, thanks. You're right bendix type instead of huck. will get out there tomorrow and check out drag link situation, i've got the entire steering gear, maybe the whole thing swaps. | | |
