2 members (Frank50, Kilted54), 71 guests, and 4 robots.
Topics128,189
Posts1,057,222
Members48,465
I finally got my project and was hoping to get some ideas for upgrades... I need to fix the brakes and would like to upgrade at least the fronts to a large power disc setup. I need to replace the steering column and I would like to add power steering, too. Also, can anyone recommend a good set of donor seats that will fit well in this cab? The original bench frame was broken and I tossed it. Do later model truck seats work or are seats from a car a better fit? I need to get these things figured out before I move on to swapping in a motor an tranny. Thanks!
Riding in the Passing Lane
Any seat other then original type will take some fabrication, but its generally no big deal. Some of these wrecked cars have some real nice seats & can be bought reasonably. Take a few measurements.
1972 Chevy c10 Cheyenne Super
88 & newer GM truck seat is almost a direct bolt in. Front seat bolts are almost perfect placing, you need to drill new holes for the rears. The 95 ( I think) and newer seats have the seat belts attached to the seats.
Dave
66 GMC- father /son project with the "GMC KID"
36 Chevy PU- 4x4 lifetime project
64 Skylark- wife says its hers
My 64 has some kind of later year seat.
I think it`s a mid 90`s Chevrolet seat.
The problem with mine is even when it`s all the way back against the fuel tank, my stock big steering wheel is right in my lap.
I`m going to be replacing my tank with a rail mounted one so I think this will solve my problem.
Mike
Socket Breaker
Socket Breaker
summary of seat swap q&a for 1960-1966 trucks:
http://www.chevytalk.org/fusionbb/showtopic.php?tid/86476/
power steering:
http://www.customclassictrucks.com/techarticles/60_66_chevy_gmc_power_steering_retrofit/index.html
more power steering:
http://www.persh.org/pickup/steering.htm
REZ Engineering - No website yet, call or write - power steering kit. used trucks to part out(particularly 4x4). 1960 - 1966 Chevy/GMC. - PO Box 1584 - Great Falls, Montana 59405 - Ph. 406-727-9267
ideas related to 60-66 trucks:
http://www.persh.org/pickup/IdeaPage.htm
Thanks for all the info and links!! Too bad my friend just sold the seats from his 99 he wrecked.
I've got 6 way power leather seats out of a dodge caravan or chrysler le baron with a center console out of a 98 ford explorer
fits perfect...had to drill new holes to mount to floor but no big deal....
