1 members (baldeagle),
158
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 12 New Guy | | New Guy Joined: Nov 2008 Posts: 12 | fuse was blown for heater no fan, found heater motor to be frozen and it had to be replaced. I installed a new 10amp fuse in the fuse block and everything worked as it should on all speeds low, med and high. Today I used the truck and it was colder so I placed the control on high after about 10 minutes the blower quit working on high but continued to work on low or med. A few short minutes after that it quit working all together. Found new fuse was blown. I installed new fuse and the motor worked again on all 3 speeds. Can someone tell me why this blew a fuse? I don't know much about the deluxe heaters but they look fairly simple what am I missing here. Thanks Chris | | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | It seems like the heater motor was drawing too much current through the heater. I do not know why it only quit working on one speed and then stopped altogether. Someone should come along shortly and answer. | | | | | Joined: Oct 2008 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2008 Posts: 67 | try a 15 amp fuse, if there is a short or excessive current draw it should blow the 15 too. | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | Check the fuse block for the fuse rating first, before installing a higher rated fuse, by doing so, you will avoid parlaying the problem to the blower motor or the heater resistor/heater element. Also, check the heater wiring harness to ensure there are no bare wires.
The Deluxe heater (3-speed) set-up, utilizes the same blower motor as the Thrift-Air heater (2-speed) set-up and the fan speed is controlled by a variable speed/variable resistance switch in the dash control assembly on the Deluxe heater. Have you checked the heater switch in the back of the Deluxe heater dash bezel? You may have an issue with this switch and considering the cost of a new switch, I would check here next.
I hope this information is helpful in solving your heater issue.
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Put a 20 amp fuse in it. 10 is too light for a heater motor. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Nov 2008 Posts: 12 New Guy | | New Guy Joined: Nov 2008 Posts: 12 | I checked the fuse block and the manual and this circuit calls for a 10 amp fuse. I installed the proper fuse when I replaced the motor and I really am concerned about putting a higher amp fuse in than it calls for. I assume everything should operate properly on the 10 amp fuse since that is what it calls for. If it doesnt I must have some other problem somewhere else. Also doesnt putting in a higher amp fuse than it calls for create more heat and stress on the wiring? I have always heard this can "cook" your wires. | | | | | Joined: May 2005 Posts: 96 Shop Shark | | Shop Shark Joined: May 2005 Posts: 96 | Does Anybody knows where to buy a 12v motor ?
Thks.
Jan | | |
