2 members (Leo, GRNHydra),
84
Mod | | | Forums66 Topics128,060 Posts1,055,837 Members48,427 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 324 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 324 | Wondering what you guys are using to clean aluminum? I would like to clean up my 700r4 & paint it. | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Trailer companies sell a cleaner for about $12 a gallon. Go to any trailer dealer such as Trailmobile or Wabash and ask for aluminum brightner or the stuff used to acidize aluminum. We use it all the time. | | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | on the expensive side=brake cleaner of Easy-Off oven cleaner[wear eye protection,because of spray-back]What about a soft wire brush and solvent,followed with a dish soap rinse | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | If you can clean it up nicely, you don't need to paint it. I got mine clean buy using a wire brush in my drill and Dremel tool with a wire brush or wheel. It shines pretty nicely so I left it ah la natural. Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | Easy Off oven cleaner, followed by a good bath, courtesy of the power washer or car wash...that stuff will peel the chrome off a trailer hitch ball.
To keep the factory sheen, after the clean, you can clear-coat it with a low-sheen coating. Eastwood and several other paint suppliers sell this product.
| | | | | Joined: Nov 2006 Posts: 324 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 324 | Thanks fellow Bolters for your time & consideration. I will try the oven cleaner, then pressure wash, soft wire brushes if needed. Also like the Idea of coating it with a low sheen lacquer to keep the factory clean look.
| | | | | Joined: Jan 2003 Posts: 354 'Bolter | | 'Bolter Joined: Jan 2003 Posts: 354 | I haven't looked at the labels lately but the Easy Off heavy duty liquids & griddle cleaners usually contain sodium metasilicate or potassium hydroxide which will slowly dissolve aluminum. The aerosol formulation doesn't list either of these as an ingredient. I would do a small test area first.
Harold Wilson 41 Chevy 3/4 Ton
| | | | | Joined: Feb 2000 Posts: 5,205 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,205 | Any good wheel cleaner should also work, look for one with a acid base. The ones made for clear coated wheels probably won't work. Simple Green or Castrol Purple will also work if you are going to the car wash, just soak them down and let them set for awhile, it will come clean. | | | | | Joined: Nov 2008 Posts: 137 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 137 | As Harold41 stated - Do not use Oven Cleaner very caustic Use a brass wire wheel. | | | | | Joined: Nov 2006 Posts: 324 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 324 | Good advise!! on the oven cleaner. Simple green & wire brushing will be my new plan.
Thanks guys | | | | | Joined: Apr 2008 Posts: 95 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 95 | Using oven cleaner on aluminum... BIG MISTAKE! I learned the hard way. Many years back we found this cool vintage oven/stove with tons of aluminum bright work and chrome trim, all in great shape. It was greasy as can be, which had perfectly preserved the finish underneath. Now what better to clean an oven with than oven cleaner right? I went to work on that thing with a can of Easy-Off... covered the whole thing... emptied the can. OK, lets let it soften up and start bubbling then wipe it off.. I can hardly wait to see it shine! As I'm standing there waiting and watching this stuff do all the hard work for me, I can see the aluminum panels and knobs and stuff start to turn white. What the...? I quickly grabbed a rag and started wiping it off. To my horror, the aluminum was all dull and milky colored. Permanently etched. All of it, RUINED! That stove has been in use in our kitchen since then, and every time It catches my eye, I am reminded of how stupid I am... or was.
| | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | Find an HVAC supply store and buy aluminum coil cleaner or A/C coil cleaner. It is pink, it will eat the skin off your hands - so wear good rubber gloves and a pair of chemical goggles. Follow the directions and you will have shiny aluminum - just like the day it came from the foundry. if you dont follow the directions you will have black aluminum.
hose it on, wait a short period of time (I think it is either 30 seconds or 1 minute (on the directions), and rinse with plenty of water. Then coat with something - paint, clearcoat, etc.
Also, if you just want to paint, PPG has an aluminum cleaner that is used when they repaint tractor trailers. Contact your local PPG / Ditzler paint supplier.
Scott
| | | | | Joined: Sep 2008 Posts: 125 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 125 | Phosphorus acid. It looks like it would glow in the dark, and it will clean aluminum better then most anything else. The beauty of aluminum is how easy it is to polish, removing shallow damage!
Who is John Galt?
| | | | | Joined: Jan 2006 Posts: 205 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 205 | I owned a detail shop and we used wheel acid. Have a gallon at home now. If your aluminum is shiney don't use and acid based chemical is will dull it.
Tom
48 Chevy 3100 Shortbox 5 window "The Big Dog"
