| | | Forums66 Topics128,035 Posts1,055,446 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 59 | Does anyone know if there is a difference in the style of ashtray from a custom cab or a regular cab of a 1964? Also, I have seen ashtrays labeled as for a AC truck or non-AC truck. What is the difference? Thanks, Mike | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | The factory dash (above the radio) ash tray in the '60-'63 are the same and the '64-'66 are the same. The A/C trucks had an under-dash mounted ash tray, because the factory location is lost on factory A/C truck, due to the A/C dash vents. There are some so-called factory A/C units, that do not have dash-mounted A/C diffuser (above radio in factory ash tray location), because the diffuser unit is located below the dash.
In any case, if you have a factory underdash ash tray, you have a rare bird. I have a few and in my travels have found very few of them that are truly factory/OEM/NOS units.
There is no difference in the ash trays on a Standard cab or Custom Comfort cab...the factory/dealer A/C equipped trucks is the determining factor.
Do the A/C truck ash trays and the non-A/C truck ash trays look the same? The dash-mounted and underdash-mounted ash trays are noticeably different and are not interchangeable.
| | | | | Joined: Nov 2008 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 59 | Thanks, I`m getting an ashtray from a fellow in Colorado. I have a big hole in my dash where the ashtray goes, so I guess it had no AC from the factory. I am planning on eventually putting in an aftermarket AC so I guess I will see if I need to change anything then. | | |
