Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (Peggy M, Wayne67vert), 159 guests, and 5 robots.
Topics128,281
Posts1,058,471
Members48,490
#47790 07/18/2005 2:36 PM
Junior Member
Junior Member
I have been having some problems with my 216 in my '46 3/4 ton pickup.
First, after putting the rebuilt engine and head all back together, I was off to register the truck for the first time. What joy! Then, BAM, a horrible rattling noise from the engine. I discovered that the guys who rebuilt the head installed the valve keepers incorrectly and it caused #1's intake valve to get sucked into the cylinder and break the guide. I took the head off and had them redo it. The piston was O.K., thank goodness.
O.K., I put it back together for the second time and after running rough for about an hour, I discovered that I had no compression in #2. I did a leak down test and discovered that #2's intake valve was not sealing. So I took the head off again, the shop redid the head and replaced the bent intake valve in #2.
I put him back together for the third time, replacing all of the gaskets as usual and started him up. All was well until, after about an hour in total driving this past Saturday, BAM, another horrible sound (deja vu) at a stoplight while we were enjoying a short trip to the hardware store. I took the valve cover off and discovered a bent push rod in #1's intake. (This is the same valve assembly that had the brand new valve guide put in the first time I had the head off.)
So far I have been too brokenhearted to do too much. This morning I did a leak-down test and I discovered that #1 intake is holding no compression and air passes right through the carb. Worse, this valve is really stuck in the guide. No wonder it can't hold compression because it can't even move. I guess that is how the push rod got bent - it tried to move a frozen valve.
With a broken heart and in all innocence, I ask you guys: What could have caused this? What do I do now? How do I prevent further mishaps?
Thanks in advance for your help.
Michael
#47791 07/18/2005 4:08 PM
H Online: Content
My first impression is to suggest that you find another machine shop. It's obvious there's something wrong with their procedures, or the clearances they're using on the valve guides. If a valve is fitted too close when the head is off the engine and cold, it will sieze up when it reaches running temperature. 3 tries is more than enough to establish that the shop either doesn't know, or doesn't care about doing the work right. If mecessary, box up that head and send it to me!
#47792 07/18/2005 4:27 PM
Junior Member
Junior Member
Michael, did you have the same rattling noise during each of these events...
#47793 07/18/2005 4:47 PM
Junior Member
Junior Member
Similar, but not the same. The first was a valve slapping up and down against the piston. The second time I did't really have any unusual noise, it was just that the engine ran rough. And the last time the noise was a more tinny as the push rod was banging against the side cover.
Each of the noisy events was precipitaed by a moment of bit unusually loud valve pounding noise though.
#47794 07/18/2005 4:52 PM
Junior Member
Junior Member
#47795 07/18/2005 5:45 PM
H Online: Content
Michael, you've got mail!
BTW, for all of you who are having sticky-valve problems on 216 engines, the factory specification for valve-to-guide clearance, according to my Chilton manual, is .004"! I'd consider that to be worn out on any modern engine, including some from the 1950's!
#47796 07/19/2005 3:43 AM
Michaellubitz,
Howdy! I live just south of Austin and will be lookin for a machine shop in the (hopefully) near future. Who did you use? I think I would like to avoid them.
Jeff
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
#47797 07/19/2005 6:59 AM
Junior Member
Junior Member
Jeff,
I used South Austin Machine. They have a real good attitude and have fixed all all of the problems so far. I have had to take off the head each time though. We'll see what they say this time about not having made the correct clearance between valve stem and guide.
Hey, maybe by the time that I am done with my 216, they will have learned by our mistakes and be able to do a rebuild without problems.
I heard (and he seems knowledgeable) good things about Travis Engine Center but I have not had any work done by them.
What kind of truck do you have?
Michael
[email protected]
#47798 07/19/2005 9:12 AM
make sure your getting oil up there tp lube the valves after 3 times i take it to a pro.
#47799 07/19/2005 2:23 PM
If you are getting oil up there, then the head was done incorrectly. You need to switch shops before you break a piston and have a ruined cylinder. It is not the fault of the engine being a 216. There were many 216s serving for many years and they weren't scrapped because of this.
1951 1 Ton Completed
#47800 07/19/2005 5:09 PM
Are you running fresh gas in the truck? Old gas will stick valves in guides.
My Blog
#47801 07/19/2005 11:36 PM
Tab Offline
That's all I run in my truck is old gas, lol... and I've had it for about 23 years.
delete my account and pictures
