3 members (MickeyP, Joe H, Jon G), 121 guests, and 1 robot.
Topics128,050
Posts1,055,646
#47780 07/17/2005 8:39 AM
Ok guys. I have a 41 half ton. I've just finished the king pins. I had to replace the spindles as one was too badly worn and the other had a slight twist in the shaft. I've put everything back together and noticed that on the side which had the twisted spindle, the brake drum is not an even fit to the backing plate. One side of the drum fits in flush inside the backing plate lip but the other sits out a little. I've still got the truck on axle stands. Ther brakes seem to work ok although I haven't taken it out for a road test yet. Just wondering what your thoughts are on this and whether it would be ok to take the truck back on the road.
Cheers
Bob
#47781 07/17/2005 2:15 PM
I would check to see if the drum is warped by placing it on a flat surface (mark the suspected high spot before you pull the drum). Also make sure the mounting surfaces are clean.
1954 GMC 1/2-ton Longbed
1971 Pontiac LeMans Sport
#47782 07/17/2005 4:41 PM
It sounds to me like you've got a bent backing plate. If the drum was warped, the tight spot would rotate with the drum. Pull the drum and the brake shoes back off, down to a bare spindle and backing plate, and do some measuring from the end of the spindle to various points around the edge of the backing plate. If it's bent, straightening it might be a real challenge. I'd expect uneven brake shoe wear if it's allowed to stay out of alignment.
#47783 07/17/2005 6:48 PM
Is it possible one of the spacers between the spindle and backing plate fell out?
My Blog
#47784 07/18/2005 2:42 AM
Thanks for the suggestions guys. I had a look at it this morning and Jerry you were on the money mate. There is a wee bend in the backing plate. I'll see about sourcing another. Allowing for some uneven shoe wear would it be ok to use as is for a short time?
Thanks again fellas
Bob
#47785 07/18/2005 12:37 PM
Bob,
I'm guessing that you probably did NOT bend it in the things YOU have done. Take a look at the old shoes you removed to check for uneven wear on them. You still may want to replace the back plate but this should give you an answer as to whether it would be ok to use it as is for a short while.
Rance
66 C10 FS/LB 292/4-spd manual (I also enjoy Hang Gliding)
I'm too sexy for my hair, that's why it isn't there
#47786 07/18/2005 4:12 PM
It might be possible to remove the backing plate, and do a little hammer-and-anvil work to straighten it. There's nothing fancy about it, it's just a steel stamping with no heat-treatment or special hardening. Try a little blacksmithing before you scrap it.
#47787 07/19/2005 12:47 AM
Rance. It would have been like that since I've had the truck. Just hadn't noticed before.
Jerry. I'll give it a go and try and straighten it. I did a pretty good job of remodelling my thumb when I was doing the king pins so the backing plate should be a breeze.
Cheers guys
Bob
