6 members (jmoore, Peggy M, Jon G, John Dlugos, DadsFirstPickup, 1 invisible), 87 guests, and 5 robots.
Topics128,120
Posts1,056,325
Members48,439
Is it possible to remove the steering column from the cab without removing the steering box from the frame? Also is there any company that makes a oem style replacement steering box set up for power steering??
Not that I'm aware....
I pulled the column/box assy before i took off the cab.... ohwell
GMC: Get More Cash...
1958 GMC
My Webshots photos
the column doesn't seperate from the box, all one piece that needs to be removed from below .... power steering requires a modern power steering box spliced to your cut off upper column, or a complete column assy from later year
I had a feeling that the column would have to come out of the bottom of the cab. does anyone make a new power steering column that mounts thru the oem frame holes and uses the stock pitman arm?? I was thinking of using the column out of my 1982 c-10 but i have never done a transplant like that before also the steering box mounts the pitman arm down and not thru the frame like the stock 59 does. my replacement motor has a good ps pump and hoses i just need a box to fit them to.
Riding in the Passing Lane
The specialty parts suppliers have a kit to install the GM power steering gear to the older trucks. I havn't done one yet but am contimplating it on my 58. Some also use the Toyota 4X4 box although i'd hate to put anything from a foriegn vehicle on mine.
1972 Chevy c10 Cheyenne Super
1 Offline
the toyota 4x4 box is by far the easiest swap. box must be pre-85' (solid axle)do your homework before you start.
