| | | Forums66 Topics128,035 Posts1,055,446 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#47741 07/15/2005 8:43 PM | Joined: Jun 2005 Posts: 16 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 16 | Time to put in a new exhaust. I was thinking of using a flexible (metal coil) exhaust tube from the manifold to the muffler. You know the kind, it resembles a vacuum hose. I figured this is the cheapest way to go. But as the wise old chinaman says, "Cheap man pay most." Does anyone have good advice about longevity vs. cost when doing an exhaust? | | |
#47742 07/15/2005 9:16 PM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | also "the bitterness of low quality lingers, the sweetness of low price is fleeting" high cost longevity = stainless repeated low cost = flex for the "vs" part don't have much cash now vs will I ever? don't have much cash vs really wanna get on the road gotta have exhaust vs gotta have brakes do I wanna do this more than once vs how long will I keep the truck? some parts places have prebent "alumanized" components, incl pieces for the old trucks, and doing it yourself can save a bunch over getting it done at a shop - I wouldn't expect the flex stuff to last a long time, if you plan on keeping the truck Bill | | |
#47743 07/15/2005 11:48 PM | Joined: Apr 2004 Posts: 703 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 703 | Urban, I don't know your financial situation... and it ultimately comes back to what you can afford.
That said, I would try and avoid the flexible tubing your describing, if at all possible.
The whole dual exhaust set-up on my 46 was done for under $250.00, including the splitting of the manifold, glass packs, all pipe, hangers, and the labor.
You might save a little bit of money going the flexible route.
However, I can tell you based upon the 47 F*rd I'm storing for a buddy, it don't take much at all to bend it, or bust it loose. Once bent, it don't go back.
We quickly and quite easily trashed his entire exhaust system trying to load and unload it from the trailer we used to transport it to my house.
I'm betting my steel exhaust system would have taken the hit and perhaps gotten a small dent at most in the same situation. | | |
#47744 07/16/2005 12:25 AM | Joined: Feb 2004 Posts: 29,750 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,750 | One word- - - - -DON'T! I used flex pipe to do the same thing on a 58 Chevy many years ago, and found out that flex pipe vibrates, and breaks at the end connections, repeatedly! I could count on cutting the pipe back and re-connecting it about every 500 miles, and it would get too short to reach very quickly. It's not worth the effort, and a custom-bent real pipe from a muffler shop doesn't cost that much! Jerry
#47745 07/16/2005 2:42 AM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | consider running them without mufflers,, that would save you a bit,, and sound great,,I could here you fire up all the way to Tx.Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#47746 07/16/2005 4:10 AM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Allright, Joker!! I guess you know by now that inline 6 cylinder Chevy engines were made to run straights!! That's where it all started!! Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | |
#47747 07/18/2005 12:19 AM | Joined: Jan 2005 Posts: 164 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 164 | Do you really want to use something cheap in the area where an exhaust leak would be most likely to sicken or kill you?
CO poisioning is insidious, it warps your thinking before you reach the level where you become unconcious (then dead).
We had a friend who got CO in their house when a roofer knocked off the water heater vent. She said she was worried she was becoming mentally ill, as she got forgetful and easily confused. | | |
#47748 07/18/2005 7:01 PM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | if'n you gotta
put the flex pipe over the steel pipe for that old harley look under the hood ha ha
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
#47749 07/19/2005 2:22 AM | Joined: Jun 2005 Posts: 16 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 16 | thanks to everyone...I'm going to get steel pipe, it's worth it. | | |
#47750 07/19/2005 5:08 AM | Joined: Jun 2005 Posts: 145 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 145 | Originally posted by urbanrefugee: I'm going to get steel pipe, it's worth it. Wheeeeeeew!!! Thruwurkin
Half Ton Will Travel God bless America...One nation under God
