| | | Forums66 Topics128,049 Posts1,055,548 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2008 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2008 Posts: 72 | Just finished putting my new motor in. This motor is a 430hp 350 (V8). My questions is how much coolant should it take? I have heard 5 gallons, four gallons, etc. When I went to fill her up, it only took in 3 1/2 gallons. With the block, water pump, and everything being bone dry, I wonder if that is enough. I have start it up a couple of times and re-topped it, but it has only dropped slightly. Heater core, and all hoses get warm, so I do have flow. Don't want to run it for too long until I'm sure that is has all the coolant it needs. Thanks. (Also posted this in the HIPO section) | | | | | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | 3 and 1/2 gallons sounds about right. | | | | | Joined: Sep 2008 Posts: 125 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 125 | Every combo is different. The radiator can be re-cored to a different thickness, the hose may be longer or shorter, the heater may be bypassed, etc. I just fill'em till they're full. Just make sure you let it warm up enough to open the thermostat, and then top it off. once you have done this you will no how much your setup takes.
Who is John Galt?
| | | | | Joined: Aug 2008 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2008 Posts: 72 | Thanks for the reply. This newby mechanic just doesn't want anything to go bad on him. I'm into this far enough that if something went catostrophic I'd have to postal or something.  | | | | | Joined: Aug 2008 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2008 Posts: 72 | I hope to have a video up in a day or two for those who would like to hear the new motor.  | | | | | Joined: Aug 2007 Posts: 462 'Bolter | | 'Bolter Joined: Aug 2007 Posts: 462 | love to hear engine and see truck by the way what is a motor | | |
